Version Detection finds one file too many
Bongo
Post by Bongo » 07 Jul 20 18:02
My settings:
Main version detection method: %FileName.jpg
Place holder all Custom File Mask:
web display: %FileName_WEB.jpg,%FileName_FFI.jpg,%FileName_FC.jpg
HD:          %FileName_HD.jpg
RAW:         %FileName.cr2,%FileName.dng,%FileName.raw,%FileName.tif
Version Detection with right mouse click found:
Main version:  2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619-Bearbeitet.jpg
web display:   2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619-Bearbeitet_WEB.jpg
HD:            2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619-Bearbeitet_HD.jpg
RAW:           2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619-Bearbeitet.tif
So it is good!
But it also finds this file without a place holder:
2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619.CR2
Why is this file found?
Regards, Bongo
Photo Supreme V5 Single User Edition, Windows 10.
Re: Version Detection finds one file too many
Post by jstartin » 07 Jul 20 21:07
Which files are detected as versions depends on "Version set detection mask" (default %Filename*.*) and "Version set offset folder". Whether or not a filename corresponds to a "Place holder matching method" has no influence on detection of versions.
Bongo
Post by Bongo » 08 Jul 20 17:29
My "Version set detection mask" is default %Filename*. *
I don't know exactly how version detection works. But I guess it starts with the main version.
Main version is "2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619-Bearbeitet.jpg"
%Filename in this case is "2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619-Bearbeitet".
Why is this file "2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619.CR2" in the version set? That doesn't fit into the mask.
Regards, Bongo
Post by Hert » 08 Jul 20 19:49
Your version set is determined based on %FileName*.* meaning all file combinations that match that mask are to be combined in a version set. The files you mention all match the mask.
Version detection doesn’t start with the main version. After all, there is no main version yet. First the version set is determined and the main version is then picked from the version set based on the rule you define.
Bongo
Post by Bongo » 12 Jul 20 15:45
I think the file "2020_06_26_1828_Canon EOS 5D Mark IV_AZ0A4619.CR2" does not belong in the version set. It doesn't match the mask.
Then I have to remove the file every time.
Regards, Bongo
User avatar
Post by G8DHE » 12 Jul 20 17:24
The file match criteria does match its %filename*.* the "-Bearbeitet" is matched by the first * the ".jpg" is matched by the second *
If the matching was %filename.* then it wouldn't match.
Bongo
Post by Bongo » 04 Oct 20 17:30
Sorry for the late reply. Why don't I get a message from you replies?
I've tried %filename.* . But then _WEB and _HD are not found. Hmm ...
Regards, Bongo
Post by jstartin » 04 Oct 20 20:55
Bongo wrote:
04 Oct 20 17:30
Look at the User Control Panel/Board Preferences/Edit notification options and set it how you want.
They no longer match the mask. If you have derived files that you do not want to be found by versioning then you need to make sure that your naming conventions and your version detection mask are designed to work together to do what you want.
