Files inside /IDimager Systems, Inc./Catalog
AlainB
Post by AlainB » 13 Jun 20 13:52
Is is safe to rename, restore from a backup or delete the files with extensions cat.db and thumbs.db ?
User avatar
Re: Files inside /IDimager Systems, Inc./Catalog
Post by G8DHE » 13 Jun 20 16:26
If you delete them you won't have a database at all!
But yes I grab copies as quick backups and restore them without any problems.
AlainB
Post by AlainB » 13 Jun 20 18:14
Apparently renaming the two files A.cat.db and A.thumbs.db as B.cat.db and B.thumbs.db is OK (I mean while Psu is not running.)
Then Psu catalog A becomes catalog B.
Deleting the two files would be a way to delete the catalog. There seems to be no direct way from Psu.
