Error updating to v5 build 2960
gcurrie
Post by gcurrie » 07 Jun 20 19:09
Running v5 Server Edition PostgreSQL (9.6).
After updating the client and initially connecting to database, I am prompted to update the database.
I then get this error:
Unable to connect to the database.
The database reports:
Something went wrong while upgrading your PostgreSQL Catalog towards version 3023 (last successful step is 3021)
TPostgreSQLConnection: Execution of query failed (PostgreSQL: Error: trigger "idsearchdataupdatefts" for table "idsearchdata" does not exist
Severity: ERROR
SQL State: 42704
Primary Error: trigger "idsearchdataupdatefts" for table "idsearchdata" does not exist)
I took a look at the db and tables in pgAdmin 4:
The table idsearchdata exists.
There are no triggers on any tables that I can find and idsearchdataupdatefts definitely does not exist.
There IS a trigger function process_idsearchdataupdatefts() that exists, but it needs a trigger.
I seem to be stuck here. Please advise how I can continue and complete the database update.
Are there any SQL snippets I can run to create the missing idsearchdataupdatefts trigger?
Gordon Currie
Photo Supreme 5.4 PostgreSQL on Windows Server Essentials 2016
Re: Error updating to v5 build 2960
Post by Hert » 07 Jun 20 19:38
Here are statements that allow you to create the trigger. The database upgrade will drop them again;
create or replace function process_idSearchDataUpdateFTS() RETURNS trigger AS $$
begin
  new.ContentTypeIdx  := to_tsvector('english', new.ContentType);
  new.ContentGroupIdx := to_tsvector('english', new.ContentGroup);
  new.ContentValueIdx := to_tsvector('english', new.ContentValue);
  return new;
end;
$$ LANGUAGE plpgsql;
create trigger idSearchDataUpdateFTS before insert or update on idSearchData for each row
  execute procedure process_idSearchDataUpdateFTS();
gcurrie
Post by gcurrie » 07 Jun 20 20:34
Hert:
I ran the supplied code to create the trigger function and trigger.
Upon trying to update the database via client connection I now get a new error:
TPostgreSQLConnection: Execution of query failed (PostgreSQL: Error: syntax error at end of input
LINE 1: drop function process_idSearchDataUpdateFTS
Severity: ERROR
SQL State: 42601
Primary Error: syntax error at end of input
Character 44).
I notice all table names, triggers and trigger functions are camel cased in your example. From within PG Admin 4 on Windows Server 2016 I see table names are ALL lower case. Could there be an issue with casing?
Gordon Currie
Post by Hert » 07 Jun 20 21:18
There’s nothing wrong with that statement. Did you install psu with the correct PostgreSQL version selected?
Names are not case sensitive. I don’t understand why you didn’t have the trigger and function in the first place. Before this alter, psu couldn’t function properly without that trigger. So it must have existed.
gcurrie
Post by gcurrie » 07 Jun 20 23:22
Hert:
Yes, correct PostgreSQL version always.
Obviously casing is a non-issue.
The script you supplied me enables me to re-create trigger and trigger function, but then the upgrade code successfully DROPS the trigger and then fails on DROPPING the trigger function. If I run the update again, I'm right back to my original error.
I've been upgrading PSU versions all spring, but this is the first one this year that required a database change. Usually they go quickly and easily.
I'm not sure of the version prior; I didn't think to check as I've never had a problem before (upgrading since PSU first shipped). It has been at least a month since my last upgrade.
Gordon Currie
Post by Hert » 08 Jun 20 8:06
This is the database upgrade the database from version 3021 to version 3022;
[edit Hert; removed the lines]
Again, it sounds like something is not right in your database.
gcurrie
Post by gcurrie » 08 Jun 20 20:58
Hert:
Thanks for this script. I was able to update the database.
I had to modify the script. When I executed "drop function process_idSearchDataUpdateFTS;" I got a syntax error. I had to DROP that function manually.
Then I was able to run the next two lines without errors.
Connecting an updated client updated the version to 3023.
I compact the database weekly. If there is anything I can do to ensure a healthy database, I'm open to suggestions.
Gordon Currie
Post by Hert » 08 Jun 20 21:37
That’s great. Apart from compacting, I have no suggestions.
Hope you’ll notice the new and improved search speed in the search box
tonydeancoscia
Post by tonydeancoscia » 14 Jun 20 17:58
Gordon,
I'm having the same problem. Can you walk me through the steps? I don't understand the entry by Hert which says [edit Hert; removed the lines]
Dean
