Batch AI Label Detection not working
Alfons
Post by Alfons » 07 Jun 20 10:04
Batch AI Label Detection always stops before completion. PS stalls and needs termination by the Task-Manager. Batch detection sometimes works with small number of images (2-3) however never with larger numbers of images selected. Running the batch with the option „Assign Catalog Labels – Assign All Labels“ is even worse. The applications stalls after a low percentage of completion. Any idea how to correct that?
Thanks and best regards,
Alfons
Re: Batch AI Label Detection not working
Post by Hert » 07 Jun 20 16:30
Can you try this with build 2962? You can download it from the website.
Alfons
Post by Alfons » 07 Jun 20 17:44
Hert, I ran several batches with built 2962. And it works. Thanks for the quick fix!
Post by Hert » 08 Jun 20 8:17
Great!
