Shortcuts witha French keyborad
AlainB
Post by AlainB » 15 May 20 16:14
I have another problem:
My computer is a MacBookPro (OS 10.14) with a French keyboard .
On a French keyboard you press SHIFT + Number 0-9 in order to obtain the numbers 0-9
It works with PSu as it should but for the shortcuts 0-5 and CTRL 0-5. No combination of keys I tried have the desired effect.
In order to use there shortcuts I have to declare the keyboard as a US keyborad !
Any hint ?
Re: Shortcuts witha French keyborad
Post by Mke » 15 May 20 17:41
<blague>
Get yourself a French Canadian keyboard? Much easier than the French one :)
</blague>
AlainB
Post by AlainB » 17 May 20 20:13
I found out that an old French Keyboard with Numeric Keypad (from some defunct iMac) does the job.
