Importing Media Pro Category tags
AlainB
Post by AlainB » 13 May 20 16:48
I am a new PS user, migrating from Media Pro.
After import of my test files into PS, the Media Pro tags "Category" appear in the Advanced XMP panel as %xmp:photoshop:Category
Is there a way to have a "Catalog Label" with this information ?
Re: Importing Media Pro Category tags
Post by Hert » 13 May 20 17:52
A warm welcome to the forum.
You can use this script to create catalog labels for any macro command;
Use right click on a selected thumb -> Run script from repository -> Catalog -> Macro Command to Catalog Label
AlainB
Post by AlainB » 13 May 20 19:00
Thank you
This macro does create entries in the Miscellaneous "Catalog Label" for the values of the Media Pro Category tags
AlainB
Post by AlainB » 13 May 20 20:19
However the macro fails for the Media Pro "Supplemental Category" when this tag is multi valued. In such a case an empty entry is created in the Miscellaneous "Catalog Label"
Post by Hert » 14 May 20 11:19
You can create a custom thumb line with your macro to check the value it holds. That will be the value that the script uses to create a catalog labels. I believe that "supplemental categories" is a multi values field and the outcome of the macro will be a comma separated list of the values. And that is what will be used to create a catalog label for. You won't get individual labels for each value.
The script was just updated and now you can use a split separator. That would make it useable for multi value results in the parsed macro value.
Again, use right click on a selected thumb -> Run script from repository -> Catalog -> Macro Command to Catalog Label
BTW; why would you create catalog labels for these metadata fields?
AlainB
Post by AlainB » 14 May 20 14:56
When I scanned my dias (years ago) I used the Media Pro "supplemental categories" to store the value of the year of the shooting.
This was may be a bad practice but I would like nevertheless Ito recover this information in PS.
Post by Hert » 14 May 20 20:15
Did you try my tip to set the macro as a custom thumb line do you can check it’s value?
AlainB
Post by AlainB » 15 May 20 10:55
I tried it for a picture with two Media Pro "Supplemental Category" A and B
The picture was assigned the Miscellaneaous category B,A
Thank you
Post by Hert » 15 May 20 12:28
use the new split option with a comma separator and you’ll get two labels
AlainB
Post by AlainB » 15 May 20 12:59
It does work.
