Error - app transport security MacOS X Catalina
Ericgenk
Post by Ericgenk » 08 May 20 12:02
Does anyone know how to get rid of the "the App Transport Security policy requires the use of a secure connection." " message when updating the country list?
Thank you.
Eric W.
Re: Error - app transport security MacOS X Catalina
Post by Hert » 08 May 20 15:54
Hi Eric, a warm welcome to the forum.
Sounds like you're using an outdated version of Photo Supreme. When the "country service" switched over to HTTPS (secured connection), Photo Supreme was updated to HTTPS as well.
What version are you using? You can see that in the upper left corner. Make sure that you upgrade to the latest version.
Ericgenk
Post by Ericgenk » 09 May 20 8:52
Hallo,
Thanks.
You are right, I used an old version. I always got the notification that there was no update.
Eric
Ericgenk
Post by Ericgenk » 09 May 20 10:01
After updating to version 2872, I still get the error?
Post by Hert » 09 May 20 11:07
Can you share a screenshot that shows where exactly you're clicking in order to get this message?
Ericgenk
Post by Ericgenk » 09 May 20 15:52
here a screenshot.
Eric
schermafbeelding
schermafbeelding
Schermafbeelding 2020-05-09 om 16.43.34.png (461.58 KiB) Viewed 1801 times
Post by Hert » 11 May 20 17:53
Thank you. Please try this in build 2883
Ericgenk
Post by Ericgenk » 11 May 20 19:17
Thanks, problem solved.
