on my w7 5.4.1.3856 slow start and crash
mantras
Post by mantras » 02 May 20 19:41
Hi
just updated to 5.4.1.3856 and under my w7 ps5 start very slow and does crash
i have to terminate with task manager
can somebody try and in case confirm?
the only fix is delete the preferences in the registry
thanks
Re: on my w7 5.4.1.3856 slow start and crash
Post by Hert » 03 May 20 0:26
Nothing changed. How you describe it it sounds like you have many open tabs. That is what most commonly slows down starting the application, as it has to reload all the tabs again on startup. Make sure that you don't keep too many tabs open on startup.
mantras
Post by mantras » 03 May 20 16:37
Hert wrote:
03 May 20 0:26
Hi Hert
i have only 1 tab active
i remove the command line and it happen only under w7
on both w10 and w7 , sometime some of thumbs are blank (grey)
thanks
Post by Hert » 04 May 20 7:24
Hi mantras. Psu is for Windows 8.1 and up. Did you always run psu on W7 before? If so, could it be that you changed something in your configuration recently? Monitor perhaps?
Post by snowman1 » 04 May 20 16:16
Without wishing to hijack the topic - Hert, I run on W7. Still on PSU v4, I have a licence for v5 but haven't upgraded yet. Your statement is making me a little nervous about doing so. Is anyone else running the latest version on W7 and is it ok? Thanks
Snowman1
Post by Hert » 04 May 20 19:24
Photo Supreme has a minimum requirement of 8.1 and higher.
Photo Supreme can be installed on Windows 7 and probably works. Windows 7 offers incorrect support for high dpi resolutions. Only with Windows 8.1, Microsoft got the high-dpi implementation spot on.
As long as you stick to old hardware to run this old OS on, you should be fine running PSU on Windows 7 and while it works it works. Windows 7 is unsupported though, not only for PSU, but also by Microsoft.
Post by snowman1 » 04 May 20 22:04
Thanks Hert.
Snowman1
