Big fan but one thing drives me crazy. :)
Rhod
Post by Rhod » 27 Apr 20 9:00
Hi - I'm a big fan of Photo Supreme and have been using it for a while now (licenced user) but one thing I find very distracting and drives me crazy: When I'm scrolling through thumbnails, the scroll is not smooth but jerky. There seems to be no logic to it either - it doesn't jump so that there is a clean row of thumbs on the top or the bottom. Maybe it's something to do with the way my brain works, but I find this throws me completely so that I'm not sure where I am in the sequence. Every other DAM I have used falls short of Photo Supreme except in this one case - they all have smooth scrolling of thumbnails. If this was sorted Photo Supreme would be perfect for me.
Thanks for all your hard work!
Rhod
Re: Big fan but one thing drives me crazy. :)
Post by Hert » 27 Apr 20 9:08
Hi Rhod, thank you for your message. What OS are you using? And what version are you currently using? The last 4 digits are important.
Rhod
Post by Rhod » 27 Apr 20 13:58
Hi Hert - thanks for your response - I'm running Catalina 10.15.4 on a 2015 Macbook Pro with 16GB of RAM.
Rhod
Post by Rhod » 27 Apr 20 14:08
If it helps at all, I've taken a short video of how it looks on my screen when scrolling through thumbs.
Post by Mke » 27 Apr 20 15:12
I don't find it as distracting - I'm used to it - but I can confirm that scrolling isn't smooth in Windows 8.1 either, and that the steps are unconnected to the mouse wheel settings.
I find that if there are many images in a folder the scrolling is fairly smooth; if few images the steps are big.
See also Mantis.
Post by Hert » 27 Apr 20 15:33
Rhod wrote:
27 Apr 20 13:58
Thank, can you also share what PSU version you’re using?
I ask because build 2834 was a major leap forward for thumb scrolling performance.
Rhod
Post by Rhod » 27 Apr 20 15:44
Hert wrote:
27 Apr 20 15:33
I'm on 2834. I don't know if it makes a difference but I'm using the built in trackpad with 2 finger scroll gesture, which is second nature to me.
I've tried attaching the vid but I get a message that the file is too large - though it's only about 5 seconds long!
Rhod
Post by Rhod » 27 Apr 20 15:48
Ok - I converted the vid and here it is.
Screen Recording 2020-04-27 at 14.07.22.mp4
(1.91 MiB) Downloaded 54 times
Post by Hert » 27 Apr 20 19:06
Thank you for the video. Can you try it now with build 2841. download and install it from the website
Rhod
Post by Rhod » 27 Apr 20 20:11
Hert wrote:
27 Apr 20 19:06
Thanks Hert - done that and it's a definite improvement. Still sort of 'juddery' rather than smooth but definitely better.
Post by Mke » 28 Apr 20 13:44
In version 2841, Windows 8.1, this is how it now looks:
scrolling1c.mp4
(255.29 KiB) Downloaded 79 times
Each step is one notch of the mouse wheel.
johnlill
Post by johnlill » 03 May 20 0:49
I have to say that I agree with Rhod. For me, on Mac Catalina, each notch in the scroll wheel jumps 3 lines, making the mouse wheel unusable for scrolling through thumbs. . I have to use the scroll bar but I'd really prefer to use the mouse wheel.
Post by Hert » 03 May 20 1:20
The scroll behaviour has changed in the latest release. Did you already install the latest update (build 2858)?
johnlill
Post by johnlill » 03 May 20 1:55
Yes. Scrolling is much improved, thanks! But it still jumps 3 lines for each notch of the wheel.
Post by Hert » 03 May 20 10:20
Below is a video of what I see. Every step is one nudge of the mouse wheel.
MouseNudge.mp4
(7.78 MiB) Downloaded 73 times
Maybe you can share a video as well so I can see the difference.
