Configure to use External image viewer
allthepix
Post by allthepix » 17 Mar 20 10:15
I quite like PSU's internal image viewer but if I wanted to use an external viewer, eg. the Windows default viewer or as a specific example, the Faststone Image Viewer, can that be configured in PSU?
Re: Configure to use External image viewer
Post by Hert » 17 Mar 20 10:54
Preferences -> Other Settings -> External Applications
allthepix
Post by allthepix » 17 Mar 20 11:15
Ah yes, I now have FSViewer as an icon on the set of external applications, but what I wanted was for the image to open in the external viewer when the thumbnail is doubleclicked but it's still opening in the internal viewer. Is that possible?
Post by Hert » 17 Mar 20 12:49
You can't replace the internal viewer.
allthepix
Post by allthepix » 17 Mar 20 16:22
ok, thanks!
