updated today to 5.3.2.2709 and I get now always a login dialog why?
mantras
Post by mantras » 12 Feb 20 17:36
Hi
i run photo supreme with a command line -d , because I want to keep v5 and v4 with 2 different database on the same machine
so i have added to v5 and v4 , -d and a local database (second ssd solid state disk)
Today 1 hour ago I got notify and I have updated from 5.3.1.2674 to 5.3.2.2709 under w10 64bit pro ,still not w7 and macos mojave
now i get always the login dialog , how can i get rid of it?
i haven't this dialog running 5.3.1.2674
i have read this topic viewtopic.php?f=57&t=27926
When The login dialog is always skipped when Server and databasename and username and password are passed on the command line. If you don't pass the username and password then the login dialog will be shown
according it , I should add command line for user and passoword to skip it?
may i know the command lines for the user and password ? and Can i know the password ?
i have never add a password to my catalog
thanks
supreme 2.jpg (30.51 KiB) Viewed 1662 times
Re: updated today to 5.3.2.2709 and I get now always a login dialog why?
Post by Hert » 13 Feb 20 0:12
Startup Parameters are explained in the Maintenance manual (click ? from the left sidebar)
The default username is admin password is master2004
mantras
Post by mantras » 13 Feb 20 8:30
Hert wrote:
13 Feb 20 0:12
Hi Hert
i have tried without luck parsing these command line
"C:\Program Files\IDimager Products5\Photo Supreme x64\IDimagerSU.exe" -D "E:\V5\Catalog\idimager.cat.db" -U admin -P master2004
I tried
"C:\Program Files\IDimager Products5\Photo Supreme x64\IDimagerSU.exe" -D "E:\V5\Catalog\idimager.cat.db" -U "admin" -P "master2004"
and with capitalized words Admin Master2004
nothing, I get always the login dialog
