Watermark not transparent
peterpix
Post by peterpix » 04 Feb 20 8:05
The watermark feature under the adjust tab has an opacity slider but it doesn't appear to adjust the opacity.
I'm using a png. It works in another app, i.e. it is capable of being made more or less opaque. It just isn't doing that in PS.
Any ideas on this anyone? Does anyone else have this issue. If so may be a bug and I might report on Mantis.
Peter
Re: Watermark not transparent
Post by Hert » 04 Feb 20 9:26
This is indeee counter-intuitive, but make sure that you set the Blend Mode to "Normal" before sliding the opacity slider. If it's none then the opacity is of no relevance
