Using DNGCopyHandler.psc with mirroring
bimo
Post by bimo » 02 Feb 20 19:20
In the introduction to that script it's stated:
"When using mirroring in the Import Module, it is possible to either mirror the original RAW file or the converted DNG file. See the comments in the script itself for further instructions."
I can't find any comment concerning mirroring; can someone help please?
Re: Using DNGCopyHandler.psc with mirroring
Post by Hert » 02 Feb 20 21:37
That was removed later because it wasn't applicable anymore. That remark about mirroring will be removed. Configure mirroring in the Import profile where you can configure if the Original (RAW) or the Downloaded file (DNG) should be mirrored.
bimo
Post by bimo » 02 Feb 20 22:33
Thanks, I will take your advice.
