Start Photosupreme with catalog from CLI
cyberal
Post by cyberal » 20 Jan 20 10:45
my PSU does not start since today on my Mac. If I start it using the icon it does not do anything (visible).
If is start it manually I get
[FORMS.PP] ExceptionOccurred
Sender=EDatabaseError
Exception=file is not a database
Stack trace:
$0000000100471D48
$00000001004C4099
TApplication.HandleException file is not a database
Stack trace:
$0000000100471D48
$00000001004C4099
Exception at 0000000100471D48: EDatabaseError:
file is not a database.
How can I start PSU and point it to a different catalog directly?
Any help is appreciated
Macbook Pro. Mac OS Mojave (10.14.6)
Re: Start Photosupreme with catalog from CLI
Post by Hert » 20 Jan 20 11:05
Try to rename the old catalog file. Then restart. PSU will then create a new database.
cyberal
Post by cyberal » 20 Jan 20 11:46
unfortunately it doesn't help.
How can I "reset" PSU completely? Also re-installation doesn't work.
starting ./IDimagerSU -portable works and the catalog opens as it should.
after it runs if I try to create a new catalog I get:
"The database file can not be found in your installation folder. Please try to reinstall the application and try again."
So it seems to be a problem with the database.
Of course I deleted Photo Supreme.app completely before re-installation.
Post by Hert » 20 Jan 20 14:50
Delete the folder ~/Library/IDimager Systems, Inc./
Any reason why you start PSU with the portable parameter? Maybe you can explain what you’re trying to achieve.
cyberal
Post by cyberal » 20 Jan 20 15:35
Perfect, it works now. Thanks a lot.
the reason why I tried the portable mode was just to find any way to get it started:-)
