multiple tabs in right hand panel?
johnlill
Post by johnlill » 03 Jan 20 17:52
New user question - is it possible to have multiple panels open on he right side if the interface? For example, can I have both the Info and Details panel open at the same time?
LifeIsLong
Re: multiple tabs in right hand panel?
Post by LifeIsLong » 03 Jan 20 21:35
I dont know of a way to do it... I've often thought it would be neat to be able to create a custom panel: select widgets from the other panels so I could assign labels and write descriptions at the same time.
User avatar
Post by G8DHE » 03 Jan 20 22:28
On the Info tab at the bottom you can hit "+ New custom field" and add whatever you want ....
johnlill
Post by johnlill » 03 Jan 20 23:02
Once again, thanks Geoff!
