Question about the update 2616
Ralf
Post by Ralf » 30 Dec 19 14:26
First of all, the update is great, points 2 and 3 are exactly what I needed :)
But what is the point 1, I can not classify or find in PSU
sorry, probably again due to my English
1.Build 2616; In Transfer profiles you can now opt to draw areas on output image (Catalog section)
2.Build 2616; You can now "delete and area" from the triangle menu
3.Build 2616; Added Alt+A as a shortcut for adding an area
by the way, points 1 and 2 work great :D
greeting
  Ralf
Ralf
(Excuse my english)
Re: Question about the update 2616
Post by Hert » 30 Dec 19 18:08
That means that when you share to create an output file then you can draw areas on the output image.
Ralf
Post by Ralf » 30 Dec 19 20:57
thanks, as always very quick answer ... great
I am not quite clear where and how it is used in PSU but I will test it in the new year. Is exactly what I was looking for
Ralf
(Excuse my english)
