I want to rename the files in my catalog adding the date to the filename.
Therefore I choose operations-rename-file and then take the date from the file and add some "-","." and ":".
Everything works, except the ":" which is shown correctly in the preview.
But after the renaming happened the ":" is replaced by a "-" (dash).
Am I doing something wrong?
Any hint is appreciated.
Warm regards,
Alex
rename file with date
Macbook Pro. Mac OS Catalina (10.15.5)
Re: rename file with date
With Windows ":" is one of the characters that is not allowed in filenames.
I am using Mac OS. Manual renaming with „:“ works fine.
You should never use colons in file names on macOS.
While the Unix layer allows colons in a file name, the Mac layer doesn't.
In Finder, if you try to rename a file with a colon then Finder gives an error: And if you use TextEdit and try to enter a colon in the file name then it is instantly replaced with a dash. This for the same reason.
Maybe consider using the date part like %FileName-%dd.%mm.%yyyy-%hh%nn.%FileExtension (e.g IMG_3880-27.04.2019-0215.jpg)
Thanks for the answers. Will use then a different character.
