How do I search a numeric range?
smadell
Post by smadell » 16 Nov 19 18:56
Simply put, how can I search metadata for a range of values?
For instance, I know I can search for all photos with a focal length of 50mm by typing: 50@xmp.focallength However, how do I search for all photos with focal lengths between 40 and 80? In other words, what are the operators for greater than, less than, and so forth?
The same question applies to dates. It is fairly easy to find all photos from, let's say, November 10, 2018. Or, from November 2018, or just from 2018. But, how can I search for photos with dates from, say, July 3, 2018 to September 20, 2018? Again, I need greater than, less than, greater than or equal to, and so forth.
Re: How do I search a numeric range?
Post by Hert » 17 Nov 19 11:23
To get focal length from 50-80 then:
1. Open Details -> Technical -> Focal Length
2. Select 50mm
3. While holding down Shift, click on 80mm
4. Optionally Bookmark the search as a favorite
To get photos from Jul 9 2018 to to Sep 24 2018 then:
1. Open Time Line -> 2018 -> 2018-07
2. Select 2018-07-09
3. While holding down the Shift key, click on
smadell
Post by smadell » 17 Nov 19 16:00
Well, that was embarrassingly easy!
