Bug with On1 sidecar?
Larry56
Post by Larry56 » 15 Oct 19 16:24
PS 5.0.0.2436 on Windows 10
I shoot jpg + Raw
I export a jpg from RAW in On1 to the same folder as the RAW adding _on1 to the jpg file name. I then Verify folders and update the catalog with the new jpg. When I delete the out of camera jpg PS will delete the on1 sidecar even though the RAW is still in the folder. I've repeated it several times.
Moving the RAW to another folder PS does have the on1 sidecar also move to the new location.
Bug that the sidecar is deleted when the OOC jpg?
Re: Bug with On1 sidecar?
Post by Hert » 16 Oct 19 7:20
The on1 sidecar is kept together with the file that have a matching file name.
If you have a file IMG1234.JPG and a sidecar IMG1234.ON1 then PSU will keep them together. And if you have a file named IMG1234_ON1.JPG and a sidecar IMG1234_ON1.ON1 then PSU will keep those together. The ON1 extension is "connected" to the same file name.
Larry56
Post by Larry56 » 16 Oct 19 16:26
Thank you Hert. I received your email in response to my web contact. I also replied to that email.
