doesn't keep full screen after the update
mantras
Post by mantras » 08 Oct 19 8:15
hi
just updated last version of photo supreme v5 2426
and i start ps -> f11 to work in fullscreen mode, i close it and when i re-open it , doesn't keep fullscreen mode
maybe it's a bug or a feature
can somebody test it ?
running w10 and w7
thanks
Re: doesn't keep full screen after the update
Post by Hert » 08 Oct 19 12:04
I've just tried it here (Windows 10):
1. Start PSU
2. Press F11 (enter full screen)
3. Close PSU (Ctrl+Shift+Q or Alt+F4)
4. Start PSU
On startup it is in full screen
User avatar
Post by G8DHE » 08 Oct 19 13:13
Doesn't do that here either, reverts to having the normal border.
Windows 10 Home x64
PSU 5.0.0.2423 64bit
edit: Ah just repeated the exercise using Alt-F4 and then it worked ok , even when using the menu>Exit which was the route I used the first couple of times above....
mantras
Post by mantras » 08 Oct 19 15:08
Hert wrote:
08 Oct 19 12:04
1. Start PSU
4. Start PSU
hi
well it did fix it !
thanks
