photo supreme mac how can I add a command line via automator
mantras
Post by mantras » 08 Oct 19 6:18
hi
i have 2 database and v4 and v5
on windows it's enough to add -d and the folder and catalog
i would like to run v5 with a command line to open a database created for v5
and i would like to run v4 with a command line an old database for v4
i want to keep v5 and v4
i'm a windows users , i don't know how can i do it under mac
i google without found an easy tutorial
how can i do under mac via automator ?
might you please post some screenshots?
thanks
Username
Re: photo supreme mac how can I add a command line via automator
Post by Username » 15 Oct 19 23:55
You could do an Applescript something like this.
Make sure you set your username and correct path and name to PSu v4 and it's DB.
set theDialogText to "Choose version of PhotoSupreme to launch."
display dialog theDialogText buttons {"Cancel", "PhotoSupreme v4", "PhotoSupreme v5"} default button 3 cancel button "Cancel"
if button returned of result = "PhotoSupreme v4" then
	do shell script "/Applications/Photo\\ Supreme\\ 4.app/Contents/MacOS/IDimagerSU -d '/Users/XXXXXX/Library/IDimager Systems, Inc.v4/Catalog/photosupreme.cat.db'  > /dev/null 2>&1 &"
else
	do shell script "/Applications/Photo\\ Supreme.app/Contents/MacOS/IDimagerSU -d '/Users/XXXXXX/Library/IDimager Systems, Inc./Catalog/photosupreme.cat.db'  > /dev/null 2>&1 &"
end if
end
- I'm the user
