Can v5 be installed along with v4?
I'd like to run v4 and v5 concurrently for awhile. Can I do that? Does v5 require a catalog change?
Re: Can v5 be installed along with v4?
Yes it updated the database on opening it. So you would need to copy the db first.
Its a pain both are installed to the same folder. Delet one and both go! Far better installing to a new folder so an uninstall of 4 doesn't require a new V5 install.
I installed v5 to it's own folder and now have decided to just uninstall v4. However, v4 is not showing up in Programs and Features on Windows 10, only v5. I have confirmed that there is both a v4 and v5 folder structure in Program Files. Do I dare just manually delete the v4 folder?
It's a poor install in my view and really needs sorting out.
