Should spaces and/or commas be avoided in keywords?
randym
Post by randym » 03 Sep 19 17:04
Is there any reason avoid commas and/or spaces in key words that are embedded in images? For example, would "LastName, Firstname MiddleName" be better as LastName_Firstname_Middlename?
Re: Should spaces and/or commas be avoided in keywords?
Post by Hert » 03 Sep 19 17:14
In general you shouldn't have to edit keywords directly when using Photo Supreme.
Create Catalog Labels instead. There's no need to avoid spaces or commas in catalog label names. On syncing, the catalog labels become keywords in the metadata
randym
Post by randym » 03 Sep 19 20:28
Thanks Hert. I should have been more specific with my question. I was aware that catalog labels are the way to create keywords in PS, and that PS searches work fine with spaces and commas included. My question concerns whether other popular applications are also fine with spaces and commas in keywords. My worry stems from the fact that not all operating systems tolerate spaces in filenames.
Also, for the benefit of other novices like me, I will note something I learned very recently: Catalog labels become keywords only if the correct options are selected in the "details of the catalog label." Specifically, under "Metadata settings", the option "Create keyword for this label" must be selected and I believe you also must select option "Mapped to" dc:subject. I learned this when a catalog label failed to show up in keywords. Not sure how the correct options were not set by default, as they must have been for earlier labels I created.
Hert, please correct me if I've disseminated any false information.
Post by Hert » 03 Sep 19 22:40
When you create a catalog label then leave all the options as default. Just name it and you're done. Change other details only when needed. "Create keyword for this label" is the default for a new catalog label. Change this only if you don't want a keyword created for a catalog label (the catalog label then becomes private).
This is not needed.
LifeIsLong
Post by LifeIsLong » 04 Sep 19 10:53
While catalog labels handle commas fine, other applications may not.
I export my photos and ingest them into Synology's Photo Station. My names are Last Name, First Name. Photo Station split these into individual tags.
So now my catalog labels are Last Name; First Name. (semi colon)
andrew.heard
Post by andrew.heard » 04 Sep 19 15:57
I use hyphens instead of spaces in all multi-word catalogue labels. It works far better when searching, for me.
Post by Hert » 04 Sep 19 16:11
For the search bar, that doesn't matter. Space and hyphen are both word separators leading to the exact same search results.
But a hyphen is the character that is used for NOT operations, which should complicate searching.
For instance;
Consider a catalog label named John Doe. You say that you would create that as John-Doe
Using the search bar, when entering
john-doe
This means john and NOT doe. So you you'd have to enter double quotes instead "john-doe" to get the expected result.
Personally I would say that John Doe plays better than John-Doe
andrew.heard
Post by andrew.heard » 05 Sep 19 19:37
I don't use not, and for what ever reason, searching for labels containing hyphens works better than labels containing spaces for me.
Post by jstartin » 05 Sep 19 21:03
Spaces correspond to an "or" search. Hyphens to a "not" search. Personally I make all my label single words, if necessary with internal capitalisation, or I use an underscore "_" as a space equivalent. So JohnDoe or John_Doe. Seems to work for me.
Post by Hert » 06 Sep 19 6:09
Unless, like LifeIsLong, you also use software that doesn’t handle spaces correctly there should be no need to cripple the names of your catalog labels.
andrew.heard
Post by andrew.heard » 06 Sep 19 8:41
An underscore is probably a better choice in hindsight.
Post by jstartin » 06 Sep 19 21:56
Hert wrote:
06 Sep 19 6:09
But I don't find them crippled, just clear, precise and trouble free, as, I suppose are %FileName and %ImageNumber :wink:
