description and visualisation screen
julienhgr
Post by julienhgr » 28 Aug 19 17:47
i am sorry for my English. He is very bad.
I have some photo with long description (5 or more line). How can i do to visualise that in visualisation screen ?
The better way for me is to add my description texte in a big part under my photo.
Like that (see attachement)
Thank you so much for your help
Julien
exemple texte.png (48.23 KiB) Viewed 294 times
Re: description and visualisation screen
Post by Mke » 29 Aug 19 10:15
Hello, and welcome!
If you open the 'details' panel, and if it is wide enough, then you can see the text:
LifeIsLong
Post by LifeIsLong » 29 Aug 19 10:54
An aside, I do think it would be nice to be able to toggle descriptions on/off anytime I'm cycling through images (so anytime I have one image in view at a time). Sort of like what the OP shows in his picture.
julienhgr
Post by julienhgr » 29 Aug 19 12:23
Thank you mke for your answer.
But your are not in the visualisation screen. You are in the other screen. I don't know the name of this screen 'result screen ' ? light table screen ? or something like that.
The visualisation screen is the screen when you double clic on the picture. This screen can be in float mode for exemple. Or in a second screen.
Post by Mke » 29 Aug 19 12:36
LifeIsLong wrote:
29 Aug 19 10:54
If you're not in full-screen mode, then you can do that by viewing the Details tab (and see much more than just the description).
If you are in full-screen mode, then you can press 'i' to show the headline and the first couple of lines of the description, as well as some other basic information.
