multi monitor support
smatzy
Post by smatzy » 13 Jul 19 22:26
Hello, with me the multi monitor support does not work if I look in the settings on second monitor place the observer is not shown on the second monitor. my monitors have two different resolutions is this the problem? if so how can I change that it still works?
greeting stefan
please excuse my bad english it is not my language
smatzy
Re: multi monitor support
Post by smatzy » 24 Jul 19 10:58
Hello, can someone help me with my problem please.
thank you Stefan
User avatar
Post by G8DHE » 24 Jul 19 11:26
have you turned on the option in PSU ?
smatzy
Post by smatzy » 24 Jul 19 22:49
Hello, I have selected it as you show it but no viewer opens on the second monitor. My work monitor is a UHD monitor and the second is a WQHD Maybe that's the problem?
Greetings Stefan
smatzy
Post by smatzy » 28 Jul 19 22:57
Hello, I've tried several settings now. The setting "viewer on second monitor" works on my Windows 10 computer only when I start Photo Supreme in windows 8 compatibility mode. Now my question should be that is the right way.
greeting stefan
smatzy
Post by smatzy » 05 Aug 19 19:06
I ask for help I have spent a lot of money on this program and can not use it properly.
greeting stefan
Post by Hert » 05 Aug 19 23:55
Hello Stephan, this is a user to user forum. Users reply to questions from fellow users.
viewtopic.php?f=1&t=22570
If you need product support then send an email to support@idimager.com
