Captions in print settings
lcushing
Post by lcushing » 10 Mar 19 0:50
When printing out a set of images and I turn on "with captions" the text appears huge and the images tiny; fussing with the "define captions text" font size appears to make no difference. Also, can I select additional fields to print, such as "description"?
Re: Captions in print settings
Post by Hert » 10 Mar 19 9:41
First of all, make sure you are always running the latest version. That is currently 4.3.3.1990
I tried it here and can make the font size smaller using the editor.
You can use macros in the text. Tip; when hovering the mouse over a caption label in the Image Details panel (e.g. over Description) it tells you what the macro name is. For the description that is
%xmp:dc:description
Use this macro in the caption text
