Postgres - Linux SUSE
rdv4rjm
Post by rdv4rjm » 13 Feb 19 9:49
Installing new server.
Could PSU run with Postgresql in Linux, SUSE version?
I see Postgres conf file may be edited as in Windows or Mac.
Would it be sufficient to be compatible?
Re: Postgres - Linux SUSE
Post by Hert » 13 Feb 19 10:44
As long as you can configure it according to the installation instructions and the version is 9.3 or 10.x, I would expect it to work. Postgresql is Postgresql.
Am I right to assume that this Linux is installed for some NAS system? Keep in mind that the performance of the database server/service may be drastically impacted by:
1. the speed of the disk(s)
2. the amount (and to a lesser degree the speed) of internal memory
3. the speed of the processor
I recommend using SSD drives for the database file.
I recommend at least 4GB of internal memory is available for the PostgreSQL process.
I recommend using a multi threaded processor with at least 2 processor cores and "sufficient" (boost) speed.
NAS systems don't always comply with above recommendations and so performance may be disappointingly low.
rdv4rjm
Post by rdv4rjm » 13 Feb 19 16:24
Thanks for confirming my very thoughts.
I am actually looking for a higher rank server.
NAS have indeed disappointed me, on many aspects for different projects.
Will keep you posted on how this project turns out.
