Dual Monitor - Redux (sorry)
davidheintz
Post by davidheintz » 14 Jan 19 18:16
Hello - new user here.
I thought I had the dual monitor thing figured out, and confirmed it here: preferences/general/images open in viewer on second monitor - but that does not seem to work for me.
Whatever setting I apply in that preference choice gives me the same result: I select the photo, hit the spacebar, and the full size image opens in front of the original thumbnail view. When I try to drag it to my second monitor, it just slides off the screen of the original monitor - in my case, to the right.
I can give you a list of raw processors and photo file management software that works with both monitors on my iMac - just about all of them. But I can't seem to get Photo Supreme to work. I really like the app. Can you help?
Thanks!
Re: Dual Monitor - Redux (sorry)
Post by Hert » 15 Jan 19 9:10
A warm welcome to the forum.
Pressing space bar opens the Quick View.
Press Enter or Cmd-O or double click to open the image in the Viewer.
davidheintz
Post by davidheintz » 15 Jan 19 16:22
Wow! That works - thanks!
