verify no longer works across folders
Post by fbungarz » 10 Dec 18 20:44
I assume this has to do with some recent changes made with multi-threading...
In my workflow I would often add images from various different folders to the image basket, edit them in photoshop and save them with a different file name, e.g., append "_edit" or "_print" to the original file name. Then, to get them into PSu, I would select all images and do "verify folder". This would scan several folders for the new files and then, at the end pop-up a dialog box with the option to add the files.
Now the verification processes all work in parallel and that dialog-box pops up briefly, disappears, pops-up again and again and again - often much too quickly for me to hit "start processing" to add the files :cry: :(
This means, it no longer is possible to use "verify folders" across different folders. Very inconvenient!
How do I know if all images in a basket/portfolio have new versions to be added? I now have to do this one file at a time. Very time-consuming. Sometimes faster (= multi-threading) means actually slower ...
Could this be changed back to who this always worked before?
Re: verify no longer works across folders
Post by Hert » 11 Dec 18 10:45
fbungarz wrote:
10 Dec 18 20:44
Don't assume ;) There were no recent multi-threading changes.
The recent speed improvements were achieved with improved database access mechanisms (like better connection pooling, less cloning, and better transaction isolation here and there. Not with multi-threading. PSU has always been fully multi threaded...not much to gain there.
You probably mean "how it always used to work in the version that I used to work with". What version is that?
It's been like this at least since the V4 release, so at least since early last February.
Post by fbungarz » 11 Dec 18 16:16
Sorry, this is incorrect. :wink:
It definitely worked in previous builds of version 4. I do not know the exact built, when this changed, but I am been using this quite a bit, it is part of my regular editing workflow. Now it is no longer working.
The last built introduced a "verify folder" to the right-click menu, when clicking a folder. Maybe that has to do with it? Maybe, since introducing this feature, "verify" now only works on single folders?
Of course I have no idea, *what* exactly changed. I only noticed that the verify process is a lot faster now and, due to my recent experience with the downloader, assumed it might also be due to "multi-threading".
I'll try out your new rename rule...
Post by fbungarz » 12 Dec 18 16:37
Could it be that this also has to do with me using a custom regfile?
Post by Hert » 12 Dec 18 16:46
no
Post by Hert » 13 Dec 18 16:09
Build 1809 improves this
Post by fbungarz » 14 Dec 18 0:52
Great! I'll check it out.
Thanks for fixing this so quickly!!!
Post by Hert » 21 Dec 18 10:52
Frank, in build 1826 (available on the website, no webupdate issued yet) you can now use the -regdb command line parameter. Use it the same as -regfile, which is now deprecated. But do specify a different filename than you did for the -regfile.
Post by fbungarz » 21 Dec 18 19:30
Perfect! Thank you!
