Set Number of Columns in Label Panel
LifeIsLong
Post by LifeIsLong » 11 Nov 18 20:37
Awhile back I had IdImager (and Photo Supreme, I believe) set to display 3 columns in the label panel by setting a registry setting within the application (from the scripter). I have been searching for the specific text, but cant find it! Can anyone refresh my memory on how to do this?
Re: Set Number of Columns in Label Panel
Post by jstartin » 12 Nov 18 12:07
If you drag the edge of the label assignment panel further out to the left it will eventually switch to three columns automatically.
andrew.heard
Post by andrew.heard » 13 Nov 18 10:06
Dragging the edge of the LAP just results in a wider LAP but still 2 columns for me.
Post by weidmic » 13 Nov 18 10:51
Post by Hert » 13 Nov 18 11:52
Keep in mind that once you set the registry key to a fixed number of columns (as described on Weidmic's page), that the automatic column calculation becomes disabled
LifeIsLong
Post by LifeIsLong » 13 Nov 18 11:57
weidmc, I tried the writetoregistry script, but I keep getting an error on line 1, position 17.
Post by Hert » 13 Nov 18 12:36
The formatting on the linked page is incorrect; this is the script:
WriteToRegistry('LAP', 'Columns', 3);
Post by weidmic » 13 Nov 18 13:24
Somehow transferring (copy paste) the page to the new provider must have messed aroundwith the formatting.
Once I have the time I will correct it.
Thanks!
andrew.heard
Post by andrew.heard » 14 Nov 18 5:16
The script worked for me - thanks. To revert to 2 columns delete registry key \HKEY_CURRENT_USER\Software\IDimager Systems, Inc.\IDI\LAP
LifeIsLong
Post by LifeIsLong » 14 Nov 18 12:04
Thanks guys! Got it working.
Post by weidmic » 17 Nov 18 18:32
I have updated my homepage :)
Also added the remark from andrew.heard and Hert
