? Bug when saving image with recipe ?
User avatar
Post by G8DHE » 26 Oct 18 15:52
Whilst playing around with various methods of watermarking an image I appear to have come across this bug;
Having created a recipe (in this case to apply a watermark) from the "Adjust" interface I decided to try "Saving as" to my testing folder, instead of saving it in the expected folder, it recreated the full path starting from the current folder down to the selected folder instead of from the Root.
I've reported it as 3302 on Mantis.
User avatar
Re: ? Bug when saving image with recipe ?
Post by G8DHE » 04 Dec 18 12:08
Got caught by this again today :-(
I assume I'm not the only one suffering this, anybody else having the same problem ?
User avatar
Post by G8DHE » 04 Jan 19 15:12
Ah just realised that this ONLY appears to happen when the drive selected for saving the new image is on a LAN connection.
Watermarking and "saving as" on a local drive works as expected.
This came to light when I checked with the latest release using my Laptop on its local drive and all seemed well. I then switched databases to the my main database where the images are saved to a network connected drive and again the problem arose with the full path being recreated from the currently active directory. Hope this helps identify the bug!!
I have updated the bug report on Mantis: https://mantis.idimager.com/view.php?id=3302
User avatar
Post by G8DHE » 09 Jan 19 11:28
Hert are you able to replicate this problem at all ?
orensbruli
Post by orensbruli » 10 Jan 19 11:57
If anybody is interested on this, I think it is resolved on this mantis thread:
User avatar
Post by G8DHE » 10 Jan 19 12:27
Yes fixed on the latest release I pulled down this morning, many tks Hert.
