Hi!
Got both pc and Mac updated with last version.
1) unable to find Preference tab under humbugger tab.
2) Unable to edit Description field under Description tab with Mac. Was able to compensate using the pc. Modification appeared on Mac instantly.
Server is Mac.
Thanks in advance if anyone would know how to go around, unless it really is an issue.
Ronald
Mac - Preference tab missing - Description not editable
Re: Mac - Preference tab missing - Description not editable
With build 1721 on Windows 10, 'Preferences' is still available in the 'hamburger' menu for me. If it helps, the shortcut is <Control>+<comma>.
1) On macOS, the Preferences are in the "Photo Supreme" main menu. This is a macOS convention; on macOS the shortcut is Cmd+Comma
2) I'm not sure what you mean with "Description tab", but the description in the Image Details is editable here. Could you try it after a software restart?
Yes, Description tab in Image Details.
Not near the mac at the moment.
Will definitely try and let you know.
Thanks for the tips.
Description editing worked after rebooting.
Main menu found as suggested.
Thanks.
Thanks.
