Short camera model in Rename script
fenschop
Post by fenschop » 22 Aug 18 8:34
Inspired by discussion on naming conventions by Stephen and snowman1 here: viewtopic.php?f=57&t=27263#p120480 I decided to change my naming and include the camera model. However this text is long, like "Canon EOS 450D" and I prefer to have it shorter, like "450D".
Are there other fields in the metadata that contain a short name? Or do I need to write a script that enumerates all camera models that I use, including phones? Hoping for a smarter solution than this brute force approach.
Re: Short camera model in Rename script
Post by Hert » 22 Aug 18 8:55
This should give you the right 4 characters of the model;
%xmp:tiff:Model{right=4}
fenschop
Post by fenschop » 22 Aug 18 9:30
Is there a good reference to the syntax (like you applied above). My current approach is trying to find examples on this forum.
sanphotgn
Post by sanphotgn » 22 Aug 18 13:02
fenschop wrote:
22 Aug 18 9:30
Under Help. The "Quick Manual - Macro Commands".
Post by Hert » 22 Aug 18 14:06
fenschop wrote:
22 Aug 18 9:30
Click the menu in the rename dialog...that's how I did it (I don't remember all these things). Here's a short video
https://cp.idimager.com/support/videos/rename.mp4
