Restore version 3 Backup into Version 4 Installation
deccos
Post by deccos » 17 Jul 18 14:38
For whatever reasons, I have ended up with a new PC that is running aversion 4 install of Photo Supreme (trial at present, I will purchase once I get all this working)
I had PhotoSupreme v3 licensed and working on old PC. Before it died, I had a backup done within Photo Supreme
On the new PC, When I do a PS restore and point it at the folder containing the backups, it appears OK - says it is successful. However, when I restart PS it just has a default set of categories etc. nothing from my old installation.
Re: Restore version 3 Backup into Version 4 Installation
Post by Hert » 18 Jul 18 6:50
Enable the login dialog in Preferences
Then in the login dialog, select your old V3 database
After logging in, you can disable the login dialog again
