I know there is some trick to this involving export to XML, but it isn't documented, as far asa I can see, and I can find anything through a forum search, so ... please ... what are the steps to import a PhaseOne MediaPro v2.3 catalog into Photo Supreme v4.1 ?
David
import PhaseOne MediaPro v2.3 catalog?
Re: import PhaseOne MediaPro v2.3 catalog?
Easiest is to just import the file from the file system using “Import from Folder” in the hamburger menu.
Also read this: https://www.idimager.com/mediapro-to-photo-supreme
I'm maybe missing the point here, but if I do:
1. choose "Import from MediaPro" from Data>
2. Browse to a ".mpcatalog" file
then the file is not selectable.
I've tried older versions of MediaPro files, going back to Expression Media, and nothing.
Trying (e.g) "Import from Lightroom" allows me to select a Lightroom catalog.
The Media Pro import expects an XML file as exported from MediaPro.
But again, I recommend to import the file from the file system instead of importing from the file.
So, basically you're telling me that the feature doesn't work?
That's not really what I expect when I pay this amount of money. Version 4 is actually a big step forward, imho, in terms of usability and intuitiveness in exposing Photo Supreme's core concepts and strengths. And it seems to perform better and seems a lot more stable than v3. And therefore I have (had?) finally decided to commit to it 100%.
But I have literally decades of work in MediaPro catalogs that I want to import, that I imagined I could import (the _catalogs_, Hert, not the files, I imagine you of all people understand the difference) based on the clear, unambiguous "Import from MediaPro" menu item. And now you're telling me that's a sham?
And yes, I know all about writing keywords to file, to xmp, to whatever. All fine in its own limited way (and actually in some cases not fine at all). But that is NOT "Import from MediaPro".
I’m not saying it doesn’t work.
The XML export file that MP creates contains less than what MP writes to the metadata and so importing from file metadata will give you a better result. Use the regular import. Try it on one or two files and check what roles in.
ok... if that's the best I can have I guess I'll have to live with it.
I basically assumed that "Import" meant that you could read the .mpcatalog file. It doesn't seem an unreasonable assumption, since the menu option is at a peer level to other options which clearly do read the "native" formats.
Never mind.
Never mind.
