PSU v4: Renaming of Folders does not work anymore
tumirnix
Post by tumirnix » 03 Jun 18 18:24
I wonder with which version the renaming of folders disapeared. I'm not sure, if I have ever used it with version 4.
Nevertheless, am I the only one who is not able to rename a folder in PSU?
I'm trying it in the "Folders" tab by a right click on the folder to be renamed and selecting "Edit Folder Name...". Then I change the name, hit "Enter" and I get the folder with the same name as before.
Is that a bug or do I something wrong?
Best regards
Martin
PS. I'm talking about the version 4.1.0.1513
Re: PSU v4: Renaming of Folders does not work anymore
Post by Mke » 03 Jun 18 23:14
You're right - can't do it here either on Windows. Have filed a bug report in Mantis (3259)
tumirnix
Post by tumirnix » 06 Jun 18 21:02
It seems to be fixed with the new version 4.1.0.1526.
Martin
Post by Mke » 07 Jun 18 21:38
Yes, it's listed as a bug fix in build 1526 and working fine again. Thanks!
