Renaming give access violation?
Username
Post by Username » 23 May 18 6:11
A few versions ago I renamed some files via right click menu for testing purposes and it worked great.
When I yesterday wanted to rename/change name to capital letters I simply got an Access Violation.
No matter if the file was a new NEF or an old jpg or if I tried to change to lower case from upper or from upper to lower.
I restarted the PSu server version.
Remounted the server volume the photos are stored on.
Down graded from 1511 to 1486 but same problem.
Anyone else that have seen this?
- I'm the user
Re: Renaming give access violation?
Post by Hert » 23 May 18 8:52
The version on the website is updated to build 1513. Does it still happen there?
Username
Post by Username » 23 May 18 20:04
1513 worked like a charm, Hert!
Thank you.
- I'm the user
