Finding and removing Duplicates
Jas
Post by Jas » 07 May 18 2:15
By accident i imported a bunch of pictures several times. Any easy way to sort them out and delete the extras?? I have been searching for the "-.1jpg" etc but the search takes a dash and an underscore as the same.
Re: Finding and removing Duplicates
Post by Hert » 07 May 18 7:32
It's not possible to import the same pictures several times, unless the media has changed (e.g. you replaced the hard drive).
Open Folders and then check if you have duplicate top nodes. Do you, then right click on each of the duplicates and select "Map to the correct physical folder" and point to the correct root on the file system
