All NEF's are black after writing metadata with 4.1.
Tester63
Post by Tester63 » 01 May 18 10:48
After writing metadata in my NEF files with PSU 4.1 (tried bd 1402-1448) Capture NX can open the file but the picture is black. If metadata is written in XMP file, there is no problem with files in Capture NX. This problem did not exist in PSU 4.0.
Thank you for your help.
Username
Re: All NEF's are black after writing metadata with 4.1.
Post by Username » 01 May 18 22:45
I just tested this for verification and I can confirm this problem.
If I create a Category. Lets say I call it "Night" and set PS to save it into the NEF, Nikons NX-D and NX-I shows a black image and seems to hang at creating the preview step.
If I simply disable the category, the Nikon applications are able to read the photo the same split second it's saved "clean".
PSu Server 5 & Postgres 10 on macOS 10.14
- I'm the user
Post by fbungarz » 01 May 18 23:06
It is not a good idea to write metadata into raw files (except DNGs). I would disable that option.
Tester63
Post by Tester63 » 02 May 18 12:44
We could make a long debate on this point, but the fact is that the option exist in PSU so, it should work correctly. Otherwise, it should be removed.
