sort by macro command-multiple custom fields?
sparta
Post by sparta » 19 Mar 18 14:09
Hi there. I am still very new to Photo Supreme (am switching from Imatch) and also still using version 3, so I apologize if I am asking an obvious or obsolete question. When using the "sort by macro command", is it possible to choose more than one custom field? I would like to sort on multiple custom fields simultaneously, like first by icd:Name and second by icd:Feature. Thank you!
Re: sort by macro command-multiple custom fields?
Post by Hert » 19 Mar 18 14:33
Hi Sparta, you can combine the two. The entered macro commands will be parsed as a single string; so
%xmp:icd:Name %xmp:icd:Feature
is a valid string.
sparta
Post by sparta » 19 Mar 18 15:19
Thanks! I tried that and didn't think it worked...but clearly I did it wrong! Is it possible to save specific macros for quick selection?
