Click on sync indicator - it was very handy
Post by weidmic » 12 Mar 18 13:02
Hert,
I loved to be able to click on the sync indicator to get an image in sync.
This feature has been dropped a long time ago, I believe because of some 'misunderstanding' what exactly happened when someone clicked on it.
I use the shortcut STRG + S very often, but sometimes it would be much faster if someone could just click to save the metadata to the file...
Maybe you have an idea to introduce a handy click feature to save the metadata to the file :) - (no intelligent sync)
Re: Click on sync indicator - it was very handy
Post by Hert » 12 Mar 18 16:03
Below's a custom thumb line that allows you to click something to write XMP to file
http://repository.idimager.com/openreso ... 5C09753B47
You're underestimating what Ctrl+S does :). Writing XMP to file is always intelligent. It handles catalog label to keyword mapping, handles additional metadata that may be defined in catalog labels, creates MWG areas for face areas, writes ICS schema if needed, maps to other schemas where needed (like Microsoft schema). And probably more that I now don't think about.
Post by weidmic » 12 Mar 18 20:23
SWEET!
I would never underestimate anything within PSU :mrgreen:
Thanks!
Post by weidmic » 12 Mar 18 20:36
