Import profile issue
dickl
Post by dickl » 25 Feb 18 19:55
Second time this happens. Insert SD card while PSu is running, preview screen opens up. Assign labels and details, click import and all seems to go well... Then after the thumbs are created a process sticks "Import Dick's Import Profile"... preparing Import... When I try to check my import profiles, the drop down window at the top is truncated as seen in the attachment. On checking the result of my import profile, my images were renamed, placed in the correct folders as they should be. Only the Activity tab sticks at the bottom suggesting PSu is trying to prepare my import profile???
Dick
Re: Import profile issue
Post by Hert » 25 Feb 18 23:52
Hi Dick, are you using the latest 1032 build? And what OS version are you using? Windows 10?
dickl
Post by dickl » 26 Feb 18 2:40
Yes. I wanted to fill that in before posting and forgot...
Installed 1032 before mounting the SD card. Windows 10, Version 1709 build 16299.248, 64 bit, Intel Core2 Q6600 2.40 ghz with 4gb memory.
Larry56
Post by Larry56 » 27 Feb 18 5:29
I've had similar issues but haven't been able to determine if bug or something on my system. I did a small import today of only 8 files and it stopped with the same message. Files were imported and details applied correctly. Yes, build 1032 on Windows 10.
[Edit]
Originally I didn't read this post properly. I have not had the OP issue on my computer. However, I just now had it.
dickl
Post by dickl » 27 Feb 18 17:10
Just to add to this topic... Bought a Dell XPS 13 running the same version of Windows 10... 4KHD screen 3200x1800 resolution... Pulling down my Import profiles works fine here... But on my 1920x1080 screen on my desktop the Import Profile pulldown is truncated,,,
