Displayed Description field
Larry56
Post by Larry56 » 17 Feb 18 19:19
When I select a thumbnail and then look at Info pane there is a limited number of lines of the Description field displayed. Some of those fields have more information that I can see. I can't re-size the box so viewing the full contents can be a problem. Anyone else have this problem and if so do you have a work around?
Photo Supreme v4 (but was also in v3) on Windows computer.
Re: Displayed Description field
Post by Hert » 17 Feb 18 21:51
You could add a custom field for the description
Larry56
Post by Larry56 » 18 Feb 18 0:23
I tried adding a custom field but it didn't wrap. Perhaps I used the wrong custom field? I selected and existing field and selected description. Another way to do this?
Larry56
Post by Larry56 » 20 Feb 18 18:39
I just installed update to 1023 and the line wrapping of the custom description field is fixed. Thank you.
