Can't reactivate PSu after minimizing [solved]
freudenthaler
Post by freudenthaler » 07 Feb 18 21:49
I have the strange situation, that I can't reactivate PSu after minimizing (Win 10). The IDimagerSU/Photo Supreme process is still running, active and visible in task manager - interestingly no menu command from the task manager (switch to, bring to foreground, maximize) is able to bring back PSu to visibility.
This already was the case with PSU 3 and is still the case with version 4. Anybode else encountering this problem?
Robert | glass stories | Fuji X | LR Classic CC | C1 | PSU 4+5 | Win 10/64 on i9-9940X |
Re: Can't reactivate PSu after minimizing
Post by Hert » 07 Feb 18 23:51
Could it be that you have software installed that hooks into Windows? Things like screen capture software, hot key software, key store recording software....
freudenthaler
Post by freudenthaler » 08 Feb 18 8:40
Yes Hert indeed, I have a screen capture SW running (Techsmith's SnagIt). Will give it a try of deactivating the hotkey functionality. Otherwise this doesn't make any problem with all my other application...
freudenthaler
Re: Can't reactivate PSu after minimizing [solved]
Post by freudenthaler » 08 Feb 18 20:23
Identified the wrongdoer: a second monitor taskbar substitute called "Dual Monitor". Deactivated this little piece of SW and everything is fine again :-). Screen capture tool (SnagIt) doesn't do any harm. Thanks for the hint Hert.
