Photo Supreme version 4
Post by Stephen » 06 Feb 18 15:43
Wow, that looks good! I can't wait for the time to try it out. Thanks. :D
sanphotgn
Re: Photo Supreme version 4
Post by sanphotgn » 06 Feb 18 16:54
Will the install of version 4 overwrite an already installed version 3? Thank you.
Larry56
Post by Larry56 » 06 Feb 18 18:30
On my install it was going overwrite v3 so I changed the destination folder's name. While that created a new install v4 will do a database update that's not compatible with v3. To test I tried opening v3 but received a warning that the database isn't compatible with that version and so it closed.
