Selected files output as textfile?
Post by RobiWan » 11 Jan 18 16:09
for some reason sometimes I need select images with different criteria and then I need output as text file. How I can realize this?
sanphotgn
Re: Selected files output as textfile?
Post by sanphotgn » 12 Jan 18 4:59
What type of output would you like to see in the text file? File name? Metadata? You can export metadata from selected images by right clicking on the selected files and going to Metadata - Export Metadata To CSV File. Select the fields you want to export. The first field is automatically the path to the file, including the file name. A CSV file can be opened by a text editor.
Post by RobiWan » 12 Jan 18 14:34
I would have path + filename. I will try with export to CSV file. Thank you.
