Merge 2 Catalogs?
MikeNaylor
Merge 2 Catalogs?
Post by MikeNaylor » 18 Nov 17 16:07
Does anyone know if its possible to import a PSu catalog into the current PSu catalog - like you can in Lightroom?
Apple iMac (Retina 5K, 27-inch, Late 2015), macOS High Sierra, Photo Supreme 4, Lightroom Classic.
Re: Merge 2 Catalogs?
Post by weidmic » 19 Nov 17 16:45
Hello Mike,
as far as I am ware, this is not possible.
However, when you write the the catalog data to the IDimager ics schema (enable it in the settings), then you can 'import' the images to any catalog you wish...
MikeNaylor
Post by MikeNaylor » 22 Nov 17 14:44
Many thanks, but what is an ICS Scheme and do I need it for anything else?
sanphotgn
Post by sanphotgn » 22 Nov 17 15:21
MikeNaylor wrote:
22 Nov 17 14:44
See screenshot below. Found in Preferences - Synchronize Settings - Write settings. To view tool tips, click on the Tips button and float mouse over an item.
