Removing Geo Data
Alder
Removing Geo Data
Post by Alder » 19 Oct 17 1:22
Hi.
I've got about 1000 images with Geo data and I want to remove it. I tried the "Geo Remove" batch command - that doesn't work. I've tried removing it manually - and I can't make it work.
What I did.
Select all the Geo Tagged images
Entered 0 in the Lat, Long and Alt fields
Hit "Yes" when told that this would remove all the Geo data.
So far, so good - the count of Geo tagged images decreases to zero.
Then the Synchronize Service runs - and it puts all the Geo data back.
I've tried this lots of times - I've changed preferences for Synch but no matter what, the behaviour is still the same. Whatever changes, Synch Service puts it back. Can anyone help, please?
Thanks in advance.
Re: Removing Geo Data
Post by Hert » 19 Oct 17 6:26
Sounds like you have Places - Catalog Labels assigned. The on sync these write the location. Unassigned these labels as well.
