Photo Supreme on Mac Connection error
rblink
Post by rblink » 12 Oct 17 23:24
I've read through as far as I can find in the support about connection issues, but can't get my Mac to talk to MSSQL server.
Scratching my head on this one.
SQL is 2016, which it didn't want to install on, but exported the SQL script and updated the commands that aren't available. It works great for the windows version, so I doubt that's the issue here.
Using just the database server name, get the Error 20009 Unable to connect: Adaptive Server is unavailable or does not exist.
Adding the Named Instance (MSSQLSERVER) gets me: Error 0:
Just using IP gets me: the 20009 error
Changing to IP + Named Instance gets me: Error 0:
There is no firewall on my workstation
Windows install works great.
rblink
Re: Photo Supreme on Mac Connection error
Post by rblink » 25 Oct 17 20:45
More information...
I got our server team to add an instance alias (the default instance name wasn't happy)
now we are trying xxx.xxx.153.117\sqlalias and xxx.xxx.153.117\sqlalias,1433 to no avail.
any ideas?
Post by Hert » 27 Oct 17 3:08
This is typically a DNS error. Try to google on the SQLServer error message. There are many possible solutions to be found.
rblink
Post by rblink » 08 Nov 17 21:55
DNS shouldn't be an issue due to using the IP addr.
rblink
Post by rblink » 10 Nov 17 0:50
I just ran some experiments.
MS SQL Server 2016 - no connect
MS SQL Server 2017 - no connect
MS SQL Server 2014 - Connect success
Are the Mac Libraries not compatible with > 2014? Is this a feature that is coming?
Post by Hert » 10 Nov 17 9:45
The last supported version is currently SQLServer 2014. Of course newer versions might be supported in future updates.
rblink
Post by rblink » 06 Feb 18 18:40
Does v4 for the mac, support SQL 2016/2017?
Post by RobiWan » 07 Feb 18 9:23
rblink wrote:
06 Feb 18 18:40
11. Added support for SQLServer 2016 and SQLServer 2017
rblink
Post by rblink » 08 Feb 18 18:35
I saw that, but i've been having (the same as v3) issues getting it to connect to MSSQL, so I wanted to verify.
rblink
Post by rblink » 24 Feb 18 1:26
Losing my mind here. downloaded the V4 (Mac) trial for a clean computer, tried pointing it at our existing SQL server, tried all the permutations of connection (machine name, full dns name, IP addr, machine name\MSSQLSERVER, full dns name\MSSQLSERVER, IPaddr\MSSQLServer) then repeated the above on a new sql server with a new create script.
PLEASE HELP!
Post by Hert » 24 Feb 18 7:41
The connection string should be <machinename>\instancename (note the backslash)
If your server is named MYSERVER and your SQLServer instance name is MYDATABASE then a typical hostname string is:
MYSERVER\MYDATABASE
If that doesn't work, then try replacing the server name with the server's IP number; e.g.
192.168.0.100\MYDATABASE
Also make sure that you've installed SQLServer according to the instructions. My default SQLServer doesn't accept IP connections from outside so that must be enabled. And SQLServer must be configured to accept custom user names instead of OS user names (Mixed Mode). Also make sure that no firewall on the server is blocking connectivity.
