Adding a rating (sometimes?) causes tags and descriptions to disappear
barneagle
Post by barneagle » 18 Apr 17 20:13
I have just set about applying ratings to some photos which I had previously tagged. I noticed that, for some pictures, after applying a star rating where previously there was none the keywords disappeared from the Details panel. When I looked at the file Properties in Windows Explorer the "tags" had disappeared. Fortunately, I noticed that in the Assign panel the labels were still present in PSU and after using Ctrl-S to save the metadata the keywords reappeared in the Details panel and the tags reappeared in the Windows file properties.
In another instance I noticed that, after applying a star rating, the Keywords/Tags remained but the Description I had previously entered disappeared from the Details panel and it was no longer shown against Subject in Windows Properties. This time saving metadata did not cause the "Description" or "Subject" to reappear.
Is this behaviour to be expected? What can I be doing wrong?
Re: Adding a rating (sometimes?) causes tags and descriptions to disappear
Post by Hert » 19 Apr 17 7:19
Sound like you have a legacy of existing discrepancies between XMP and other metadata.
Do this to fix your discrepancy:
1. Select thumb(s)
2. Right click
3. Select Metadata -> Convert Metadata to XMP
PSU will then make sure that metadata from other sections (Exif/IPTC) is correctly converted to XMP. There are unfortunately too many tools out there that write XMP sections without migrating the existing metadata to XMP...leaving you with discrepancies. Then in PSU those will become painfully clear as PSU is fully XMP driven
barneagle
Post by barneagle » 20 Apr 17 8:50
Thanks for the advice. As a matter of interest is metadata converted to xmp as part of the Import process?
Post by jstartin » 20 Apr 17 13:45
Exif and IPTC from the file are converted to XMP (all are metadata :wink:) in the database during import provided that there is no XMP already in the file. If PSu detects that XMP already exists in the file then reconversion/further conversion does not happen automatically. If other applications have written partial or malformed XMP (many do) then you get problems. Most are fixed by forcing PSu to start again by converting Exif/IPTC to XMP explicitly. Some applications (raw converters mostly) write their own stuff into the files as XMP, but not the standard metadata. PSu may overwrite this during Convert Metadata to XMP causing some information loss.
MikeNaylor
Post by MikeNaylor » 25 Nov 17 16:47
Does this apply to files from Lightroom?
Post by Hert » 25 Nov 17 18:41
Lightroom is good in its metadata writing and its XMP support. Unfortunately this can't be said from all software out there. Some think that they offer XMP support but just writing some metadata that that product suports XMP (like just a rating or only a set of keywords). But Lightroom does it the way it should be...all metadata is written to XMP and if needed LR will convert pre-existing metadata to XMP.
